traction need help...
I just finished my motor and now i need some traction mods. Im also getting my 4.10's installed for my birthday on the 31st. I think you guys can see the problem with having close to 300 rwhp 4.10's no suspention mods and only 17 245's all the way around. Right now if i floor it in 1st i break loose from around 2,000 all the way up to the rev limiter. im looking to run at englishtown in the spring since i live about 2 minutes away.
I know probably the first thing i should get is tires but i dont wanna spend over 1,000 on tires and rims right now until i need them...
So basically im looking for suspention mods. What are the first mods i should be looking at as far as suspention goes?
thanks...
thanks...
Tires are the HEART of your suspenshion but if you dont want to go that way do this:
Lower and upper control arms from a good company: Maximum Motor sports, Steeda, ect. if you can drop a little more get a phanard bar as well. all of that should tide you over for a god long while. If you don't have Subframes yet, invest in those too.
Later
Later
okay i know i said no tires but i was just looking around and i was thinking of just getting cheap rims and some slicks for the track. DOes anyone have any possible suggestions for the cheapest way of doing this?
I would look into some full length subframe connectors, lower control arms from UPR, strange 10-way adjustable shocks, and some nice drag radials (Nitto 555r if you drive the car a lot, BFG drag radials if you drive some, and M/T drag radials if it isn't going to see rain or a lot of street time)
Sep 8, 2015 11:50 AM
