pi vs ported pi flow
Old Jan 20, 2009 | 04:58 PM
Frostbitten's Avatar
Frostbitten
they look pretty hogged out from that pic. need some better pics. did they do anything to the combustion chamber or the exhaust ports? Just make sure that none of the ports were opened up past the lip of the gaskets. If they were its not going to seal. If all the gaskets seal on it you should be fine.
Old Jan 20, 2009 | 05:02 PM
stangalator's Avatar
stangalator
exhaust is unported, he told me that most porting jobs dont touch that side, is that true?
Old Jan 20, 2009 | 07:59 PM
Ehmark's Avatar
Ehmark
That sounds like bs. more air going in means you have more exhaust coming out. I am by no means a machinest but my ported heads have the exhaust ported as well as intake.
Old Jan 20, 2009 | 08:19 PM
livefast1's Avatar
livefast1
2v exhaust ports dont need much work but should have the cast flashing cleaned up, whole port cleaned up and the bowl can use a little work.
look in your intake port and see if there was any grinding done on the turn on the floor of the port by the valve. if it looks like they grinded alot there then i wouldn't even consider putting the heads on.
Old Jan 20, 2009 | 11:21 PM
stangalator
ok good, so most people dont port the exhaust side, i guess it makes since you only want to go as big as your header diameter, 1 5/8 inch, and more and its pointless for flow...
it makes since in terms of fluid mechanics.
Old Jan 21, 2009 | 10:41 PM
william_ace's Avatar
william_ace
Originally Posted by avexhype
interesting, i actually heard from alot of ford people and mechanics around town that NON-pi ported heads flow alot more than ported pi heads. i cant vouch for that though
i'd like to hear more on this.... anyone know?
Old Jan 22, 2009 | 12:51 AM
avexhype's Avatar
avexhype
^ someone replied saying that when you port out NPI and PI heads that the difference in flow is neglegible
Old Jan 23, 2009 | 01:14 PM
stangalator
here is some more pictures of the things i got a few days ago and a better shot of the ported area!
what do you guys think?
Old Jan 23, 2009 | 01:25 PM
97modifiedmustangGT's Avatar
97modifiedmustangGT
wanna sell those 24lb injectors?
Old Jan 23, 2009 | 02:06 PM
Bullitt5339's Avatar
Bullitt5339
I wouldn't use those heads, and here's my reasoning:
#1 Porting a head without a flowbench is like porting them blindfolded, you don't know what you're going to end up with. It's possible to make lower HP numbers if they weren't done correctly.
#2 Whoever did the porting didn't touch the area that needs work the most.
