TB/Plenum installation???
Old Jun 7, 2005 | 01:59 AM
freeunit's Avatar
freeunit
Default TB/Plenum installation???
Ok hopefully my TB/plenum will come tommorow and i had a couple questions. Before i start to take stuff off do i need to disconnect my battery so it doesnt mess with the computer? Also i installed my C.A.I my self should this installtion be just as easy? HOw long do you think it will take? If i need to do any other stuff that i might not know of please help me out thanks...
Old Jun 7, 2005 | 02:12 AM
andy98gt's Avatar
andy98gt
Default RE: TB/Plenum installation???
Yeah, I put my TB and plenum on in about an hour. I took my time to. I didnt disconnect my battery. Atleast i dont remember doing it. I just let it idle for about 5 minutes first. You wont need to do anything else. Just make sure your throttle cable is hooked up good. Sometimes people have trouble w/ them. Took me about 5 minutes to figure out exactly how to hook it up tight. Make sure its not loose.
Old Jun 7, 2005 | 02:13 AM
sfi's Avatar
sfi
It took me 30-40 min. yes, you have to disconnect the battery. You may need some allen wrenches. There's detailed instructions,don't rush. It pretty basic common sence,don't drop any thing into the intake. You will have to take the tube on your CAI that connect's to your throttle body and remove it until your installation is done. Then rehook the CAI to the TB first/then the MAF. Much easier for me to connect it that way. Your throttle linkage may seem alittle loose compared to your stocker, but I have had no issues. Pump the peddle a couple of times and it should be fine.
Old Jun 7, 2005 | 02:35 AM
freeunit's Avatar
freeunit
Alright thanks alot for the info hopefully i dont screw anything up......
Old Jun 7, 2005 | 02:48 AM
racer02GTstang's Avatar
racer02GTstang
also.. somethin i did was have a friend step on the gas and check the TB to make sure the butterfly opens all the way.. just makin sure u get 100% juice if u know what i mean.
Old Jun 7, 2005 | 03:12 AM
jkm1987's Avatar
jkm1987
plenum is pretty self explainitory about a hundred little screws just dont loose any my tb is in the mail so hopefully that wont be bad and always disconnect the battery it helps the computer adjust to the mods quickly i always do anytime install or mess w/anythign on my car engine or exhuast wise
Old Jun 7, 2005 | 09:29 AM
SilverGTV8's Avatar
SilverGTV8
I wrote a install guide for this.
75mm Accufab, C&L Plenum, and Tunable Induction Install
Old Jun 7, 2005 | 10:13 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
ORIGINAL: sfi
Why do you have to disconnect the battery? You have failed to back that peice of advice up with any reasonable explanation.
What will he need any allen wrenches for?
ORIGINAL jkm1987
Actually there are five bolts for the plenum itself, four for the TB, two screws for the IAC, two for the TPS and two bolts for the EGR. Then there is three hoses to disconnect, two cannon plugs, the cruise control cable, gas cable and spring along with the mount to disconnect and you are finished. Its a really simple job to do.
Old Jun 7, 2005 | 12:17 PM
marcuslee842's Avatar
marcuslee842
It dosen't seem simple by looking at SilverGTV8 install guide.[sm=bangbang.gif] Maybe it's easier to do in real life instead of reading step-by-step.
Old Jun 7, 2005 | 12:23 PM
SilverGTV8's Avatar
SilverGTV8
It's a breeze. The hardest part is setting the TPS if you choose to.
