Timing chain tensioners
Old Jan 28, 2009 | 05:38 PM
Xemeth's Avatar
Xemeth
Default Timing chain tensioners
How do I releive the tension on them? Is it one of the bolts holding them on? I just don't want to take the chance of busting them.
Thanks.
Old Jan 28, 2009 | 07:59 PM
Xemeth's Avatar
Xemeth
Bump.
Old Jan 29, 2009 | 12:52 AM
massred98gt's Avatar
massred98gt
take off the bottom guids. as easy as that. then if u want to take the chains completely off then you have to take the tensioner off.
Old Jan 29, 2009 | 01:00 AM
massred98gt
sry i thought u were talking about the chain. there is alittle pin sized hole in the tensioner housing. u need to stick a pin or a small allen wrench in the hole. the piston in the tensioner is held up by a ratcheting system so by stickin the pin, or whatever fits in the hole, pushes the tab in thats holding the piston up. then u can push the piston down, buts its pretty trickey. Get a haynes manual it tells u everthing u need to know about it in there.
mungodrums
Oct 7, 2015 04:01 AM
Golfsito
Oct 6, 2015 11:02 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Sep 8, 2015 11:50 AM
