Ticking normal for 4.6L ?
RE: Ticking normal for 4.6L ?
ORIGINAL: STANGTVERT
knocking=bad
knocking=bad
I've had a cheap car before that knocked BAAAAD (it was a 1980 Buick that was worthless, I let the knocking rattle away because it sounded kinda cool in high school), and this isn't nearly as bad, but it seems too happen under the same sort of throttle conditions (ie uphill, under torquing), but mostly at higher revs like 2500 +
I think I'm going to go to a mechanic on the weekend and have him test drive it and see if he can take a stab at what it is...
Dave,
You know the difference between a knock or a tick? We are talking about opposite ends of the spectrum here. A common problem on the 4.6 is an exhaust leak from the collector pipe joint. Doesn't seal with a typical gasket...might want to check that out. The 4.6 is a relatively quiet engine. Ticking isn't normal...
ORIGINAL: Jglisson
Dave,
Dave,
ORIGINAL: 2k1gt
Mine does the same thing. it kind of sounds like the rattle of a rattle snake. I need to get it fixed cuz its anoying the hell out of me
ORIGINAL: Dave2000GT
Yeah I do know the difference between knock and tick, but... it's VERY hard to tell the difference in my car's case. If it wasn't for the fact that putting in high octane gas doesn't stop it, I'd swear it was knock.. it is a sort of hollow metallic sound that only occurs under heavy throttle and 2500+ rpms.. could this still be the exhaust leak ?? I'm really hoping it is.
ORIGINAL: Jglisson
Dave,
Dave,
Is your car Auto/Manual?? Could it possibly be driveline related?? Just trying to think of different possibilities...
And someone mentioned that their car sounded like a rattlesnake when under heavy throttle.. That sounds like my car, and when I had a few different folks listen, they all said it was transmission related, either loose flexplate bolts, heavily worn clutch packs/bands, etc...
My car's got 126k (80% hard) miles on the car, so either a rebuild, or a replacement are in order..
JT
95 Eagle Talon TSi AWD - 12.7 @ 103mph (R.I.P.)
00 Mustang GT - Too Slow to Race, so far....
JT
