idling problem
i have a 99 gt and i just installed a cold air intake from american muscle. after the install, the car sounds like its chocking or something and sputtering when i have it in drive and sitting still. it bounces from about 550rpm to 500rpm, back and forth when i am sitting at a light or am just still. anyone have any ideas?
one of the metal fastening straps i got was too small so i only have one at the top of intake pipe where it meets the throttle body, could this be the problem? air is escaping or something... i dont know
1) Check the hose that connects from your Air Intake to your engine-connects to the heads on the rightside. If that's lose, leaking, or gapping. You'll idle funny. This happens to me a lot. The hose will come lose every once in a while and make it idle funny.
2) Check your IAC. Yours looks like this.
IAC's can be cleaned(use the search button) depending on the condition, or replaced all together for cheap.
3) Check your MAF. If needed, buy a cleaner for it and follow the instructions.
Good luck!
You might have a leak some where as they mentioned, get a carb cleaner spray, and spray it on your CAI joints and all the joints where your engine vacum hoses connect (One at a time), if the engine dies or it idles differently (RPM drops) thats where you have the leak.
so i took the car to a ford dealership service place........ they say i need a #7 coil, coil wires, a new throttle positioning sensor and my injectors cleaned.... $750 including labor
i got a quote for that stuff and labor from another shop for $420
does this stuff sound like somethin that effects the idling and acceleration problems im having? the cold air intake install could just have been a coincidence with all of these problems after being in the winter i guess. that price sound fair?
