new TB = service engine soon light
RE: new TB = service engine soon light
Have you run the codes for it? Could be a coincidence that something went wrong or something totally unrelated happened when you installed. Autozone will check them for free.
Not necessarily. When I put in my K&N Filter I forgot to plug the MAF back in...it took a good 20 minutes for the light to come on. If you don't have a code scanner to clear it once you figured out what is wrong and it was indeed a forgotten plug, the light will go out on it's own after about 30 minutes of driving. Or you could disconnect the (-) battery cable for a few minutes.
Go to AutoZone and have them pull the code for free and come back here with it. I bet its gonna be Auxillary air inputs. I had the same trouble with mine when I installed it and reguardless of how long I unplugged the battery, it never fixed itself. I had to just keep erasing the code. I replaced the gaskets and all. I had no vacume leaks or anything.
You need to set it to somewhere between .97v and .99v. You will need to back probe the sensor with a meter to set it. it can be a pain to do. I tried to back probe it when I did my install but ended up using amy predator to read the voltage[&:]
