Power Window Problem
Old Feb 13, 2009 | 04:37 PM
halox07's Avatar
halox07
Default Power Window Problem
Hello all! First time poster here.
I have an 02 GT and on my way home from work today I realized that my driver side window wouldn't roll up. It worked a few minutes earlier.
Something clicks under the dash when I press down on the switch, but doesn't do anything when you press up. You can hear a drop in the rpms when you press up and down, so I'm assuming the switch is okay.
I checked the fuse block and the larger metal fuse was labeled as the power window fuse, and seemed to be okay. They show that both the passenger and driver side window are tied to the same fuse, and the passenger window works fine.
Anyone have any experience with these things?
Thanks in advance,
TH
Old Feb 13, 2009 | 04:54 PM
halox07's Avatar
halox07
Scratch that... Chalk another one up to the search function. I just found Ripped Camel's post having the exact same issue. I hit the bottom of the door while pushing the switch and voila! Window went right up. Strange.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
