Transmission Update
Transmission Update
Awhile back I posted about my 2nd gear WOT pausing at 4k for a second - operating normally in all other gears. Someone on here advised that I test it via going manual 2nd....
Today I tested it in manual 2nd and it did the same... accelerates until 4k, pauses for a second and moves on. The transmission is a rebuilt 4r70w and this only happened after the rebuild. So they messed up the sprag? Anyways im taking her in ... eerrrrrrr I babied her for 3k miles after the rebuild and when I finally went WOT I noticed this.
Hopefully they can get her right.
Thanks for the support!
Diagnosed
Well I took her in today and they said the transmission was fine The problem was with the ECU having a stall... I just need to have it re flashed and they also said I needed the 02 sensors replaced and to clean out the MAF. I am glad I dont have to mess with the trans!
