thanks for the help guys, im going to back off the pinion nut and see if that helps at all.
I think you need a new crush sleeve. Once you tighten it to set preload that crush sleeve is deformed according to the amount of torque placed on it. If you back the pinion nut off the crush sleeve is already crushed too far and may not fix your problem.
DO NOT BACK OFF THE PINION NUT. like already said you've over crushed the crush sleeve and backin off the nut will cause major slop in the bearings and will almost definitly ruin your ring and pinion.
I noticed I got a little bit of a whine when drained and filled my stock Diff...
Wasn't there before, but it is now, and I used the right synthetic gear oil.
It's an open diff, so I don't need the friction modifier.
