when should I see boost?
If you don't already know I have a V1 s trim. These may be dumb questions but I just don't seem to be making 8 lbs of boost so I want to make sure everything is as it should be. I should see boost whether I am driving or just revving it up right? Since its a centri it should build boost with rpms no matter what. 2nd question, say I just hold it at like 5k rpms, should the boost stay constant (say at 8 lbs) or should it drop when the rpms stop increasing?
Yes I do (hense why I said I dont seem to be getting 8 lbs). I have an intercooler and powerpipe so in theory the powerpipe should make up for the loss through the intercooler and I don't have anything else that would make me lose boost. I want to know if I am getting in and out of boost when I should be. The questions I asked are so I can compare what actually happens to what should happen.
what exactely is your gauge reading?
when are you shifting? maybe youre shifting before you reach max boost.
You're not always going to see boost when driving around. You're bypass valve will be opening in a vacuum situations allow the boost to escape when you're not on the throttle.
The boost also will increase as the rpms raise. You're only going to probably start will 1-2lbs around 3500rpms. And you won't see full boost until redline.
