clunking noise
Old 03-03-2009, 07:31 PM
GhostRider02GT
GhostRider02GT's Avatar
Default clunking noise
When I engage a gear, there is this clunk noise and a thud in the shifter. If shift super slow, I can advoid this noise and feel, if it is a quicker shift, I cannot. By quicker, this is no means a speed shift as if I was racing, just relase the clutch quicker instead of slipping it in a slower shift.
Ideas?
GhostRider02GT is offline
Old 03-03-2009, 07:39 PM
robbie01gt
robbie01gt's Avatar
bad tranns???
robbie01gt is offline
Old 03-03-2009, 07:47 PM
GhostRider02GT
hoping not. Just swapped the clutch, maybe the grabbiness of the new clutch?
If it is trans, what part? collars? actual gears er what?
Old 03-04-2009, 05:43 PM
robbie01gt
robbie01gt's Avatar
it may be the clutch. does it happen when its rolling? or if you put it in gear does it make the noise, or only when the clutch becomes engaged?
Old 03-04-2009, 06:10 PM
GhostRider02GT
only when I release the clutch
Old 03-04-2009, 06:23 PM
BlackMage
BlackMage's Avatar
u-joint
BlackMage is offline
Old 03-04-2009, 06:27 PM
GhostRider02GT
gives it a thud in the shifter and makes a clunk noise that sounds from the TOB area?
Old 03-04-2009, 06:36 PM
99mustanggt
99mustanggt's Avatar
u-joint or tranny mount
99mustanggt is offline
Old 03-04-2009, 06:50 PM
GhostRider02GT
I hope you guys are right, thats a hell of alot cheaper than a trans or rear end
Old 03-04-2009, 07:04 PM
BlackMage
BlackMage's Avatar
just put er in gear and crawl underneath and check it out, grab the driveshaft and try twisting it, if you can hear an audible clunk from the u-joints, its probably the u-joint.
Quick Reply: clunking noise
