Anyone with a Hurst shifter?
To put everything in a nutshell, my MGW was one of the first things I ever installed in my car. Ever since I started going to the track though, I've had a lot of problems going into 3rd. Even when it did go in, it just didn't feel positive. I've had this problem for a long time now and even posted about it in this forum several times but only recently I think I figured it out and that is I really have to "push" the **** from the bottom and swing it right as if I am trying to diagonally go into 3rd from 2nd. Of course regular street driving is ok but when I am trying to bang gears as fast as I could on the track, it becomes a huge problem.
I'm trying to see what other shifters I could possibly try and I remember some people told me they had the exact same problem with their MGW and bought a Hurst. I don't see many reviews about them or even pics on 99-04 GT's but mostly only for the S197's.
I also can't find it for sale anywhere except on ebay: http://cgi.ebay.com/ebaymotors/Hurst...Q5fAccessories
This is still going on for $99 and seems like a good deal. I know summitracing.com sells them too but for much more and it seems to be a bit different (their's has a gold colored bottom??).
So my question is how many different ones did Hurst make for my type of car? Hopefully just one because the one on ebay seems like a good ideal. Also, does anyone here have it? what are your experiences with it? Could you please share any pics? I am curious to see what it would look like inside a new edge. I tried searching all over for pics but I only find ones of them in S197's.
I also heard that Hurst is very heavy and notchy. I read that it is more of an old school shifter but gives you a very positive 3rd shift whereas the MGW is completely the opposite. True?
It's either this or also Pro 5.0 I heard is really good. I need something that will give me confident shifts like bang bang bang...1st, 2nd, and 3rd.
Thanks,
Brandon
Thanks,
Brandon
I would NOT buy that shifter
It does not even have shifter stops and looks exactly like the Ford one. I have found that the Hurst shifter was a bit "notchy" and later went to the Pro50 in its place. If you want one bad, PM me and I have both a Hurst and Pro50 shifter (with stop bolts) for a T-3650 in my storage shed. I now run a T-56, so I have been meaning to list them somewhere.
As for pics, unless you see it without the rubber boot and trim in your ride, you will not be able to "see" the difference. The handle may give it a way, but will not effect how the shifter itself oporates.
This is the Pro50 I have on my T-56 with the stock lever I cut down a bit. Beside it is the Hurst lever I REALLY cut down and used prior. I switched the lever a month or so ago as I was tired of reaching to make the un-even numbered gears.
Jazzer
EDIT: I have cut down my shifter boot so the lever looks taller than it really is.
Jazzer
I have a T-45 transmission and love my Hurst shifter. I have the chrome handle (according to your link its $25 extra). I don't find it heavy at all. It was a bit notchy at first but that went away with use.
Jazzer, I thought you were suppose to take out the stops for a 3650 transmission.
I have a Hurst shifter http://store.summitracing.com/partde...5&autoview=sku
I don't have the long handle
I've never had a problem with this shifter... of course I've never driven a car with a different shifter so I really don't have anything to compare it to.
You want to leave the stops installed, but just adjust them so when the gear is fully engaged, it just a "c" hair short of resting against the stops. That way, you can really BANG the gears and not really BANG the gears. This is true of all manual transmissions.
Jazzer
Thanks for the replies and pics guys. Eagle200GT, your one seems to be different from the one for sale on ebay...where did you get yours from? And Toot, does your one look the same as Eagles?
The one on ebay seems to be the Comp/Plus one. Where can you get the billet/plus one?
EDIT: Oh nevermind I see it on summit. Damn thats a huge price difference
Jazzer, that how I set up the shifter on my T-45, but I've read that the 3650 has internal stops and that the external ones are basically redundant and not needed. I just Googled 3650 shifter installation. The only installation instructions that actually said that though was B&M.
I bought mine at the local Ford dealership. They had ordered it for someone else who never came in to pick it up. I replaced the white ball with a black one from Summit. Summit has similar ones but with a different handle.
