Im trying to take the stock H pipe off my 96 GT, but I can not get the passenger side inside nut off the manifold. How can I get this off. I know its a 18mm. I have tried a swivel and all different things. Im going to try a 18mm medium deep swivel socket next i just borrowed, but if anyone knows a better way please let me know!! Thanks
I think there was a thread about this recently. Use PB Blaster. If you didn't start working already you could have sprayed the bolt then driven to heat the oil up and repeat this a couple times. These heat cycles really help. If this doesn't work take a torch and heat the bolt if you can.
Im just having the trouble of getting a socket to go over it with the length of the stud and angle its at. I was just wondering if anyone knew a certain setup that does work for sure.
no I don't I can post some in April when i get the car out I just went to a friends house where the car is and did it since he has a lift, and my dad wanted to get home and get some pizza to eat, so i was rushing to cover it back up and put it away.
