Is it possible to supercharge and turbocharge?
Look at this.
http://en.wikipedia.org/wiki/Supercharger
Right above the "Aircraft" section is a small paragraph that caught my eye. Can anyone make sense of this?
It is possible. 03/04 Cobras sometimes go twin turbo and keep the stock Eaton.
There's really no point, though, unless one is already there like the stock Cobras. Using just one or the other can make the same power as two.
there was an article on this in a recent issue of Modified Mustangs & Fast Fords, past month or so. they called it compound boost. the car made somewhere in the neighborhood of 1200 to the wheels. i have also seen this done on a 2006 cobalt ss, s/c from the factory and then they through a turbo kit on it. i wuldrather have just a s/c, lots lss plumbing
Hellion 03-04 Cobra Hellraiser Twin Turbo Kit
Hellion Power Systems has once again revolutionized the way that the world looks at mail order power. Hellion' new "Hellraiser" Twin Turbo system for the '96-'04 Mustang GT and Cobra is simply put, the most powerful, and most versatile, street system available today. This system is unique in the fact that it was engineered to work with or without a Roots style supercharger in place. If the supercharger is left in place, this system becomes a "compound boost" setup - the first aftermarket system of it's kind in the Mustang industry. This system is capable of more boost, more average power, and more low-end torque than any other system.
HELLRAISER FEATURES:
-Turbonetics Turbos capable of 1600+ hp
-100% Stainless Steel Construction-Standard
-3" Downpipes Standard
-Works With or Without Supercharger
-Largest Bypass Valve Available-1300CFM Standard
-UPR Chromoly Front Suspension-Standard
-Kits Ship Quickly so there's no long wait times!
Standard System Includes:
- 61mm Turbonetics turbos with F-1 turbine wheel, and a 1-year unconditional warranty
- High flow, high efficiency air to air intercooler
- High flow race bypass valve, 1,300 cfm
- 100% Stainless Steel tubing, with a lifetime warranty
- All neccessary hardware to install the kit
- Detailed instructions with diagrams, making installation easy
- Hellion Power Systems customer support, the best in the business
Twin Turbo F.A.Q. Section
Q: Can I use this kit WITHOUT a Supercharger in place? A: Absolutely. This kit will attach to a 99-01 Cobra intake just like our other 96-04 Cobra kit. The Supercharger is simply an option for those who want to try the Compound Boost setup .But no, the supercharger is NOT a requirement.
Q: Are there any Turbo upgrades available? A: Yes. You can upgrade to 66mm, or 76mm turbos.
Q: How much power can I expect to make with the Twin turbo system? A: The amount of power you can make is virtually limitless. Depending on how extensive the modifications are to your engine, it would be possible to make around 1,600 hp with this kit. On an '03 Cobra, with a stock engine, we made 1,188 rwhp and 1,000 ft. lbs. of torque. However, the power that you produce will depend upon your supporting hardware.
Q: Why should I buy this kit over the competitor's twin turbo system? A: Simply put, for the quality. Hellion's turbo systems are engineered with the highest quality parts available, for long life and maximum power. Hellion Power Systems includes premium parts as the standard equipment in all its kits. Our tubing comes with a lifetime warranty, and our turbochargers come with a 1-year, unconditional warranty from Turbonetics. Our twin system also includes a race bypass valve, capable of flowing of 1,300 cfm, ensuring that you will never have to buy a bigger valve as your car progresses. In addition to all of this, Hellion's customer support, and shipping times can't be beat. You can order your kit, and have it within 2 weeks from the time of order. The kit also includes an oil scavenge system that ensures that the turbos never run out of, or collect oil, preventing damage to the turbos.
System Options
Larger Turbochargers 66mm - 76mm Upgrade (both turbos) $1,190.00
Ball Bearing Upgrade ( for both turbos, any size) $800.00
TurboSmart eBoost2 Electronic Boost Controller $540.00
Bassani 3" Stainless Steel Cat-Back (IRS or Straight Axle)
Edit: Straight from Lethal
System Options
yeah but not really, that hellion kit is just a gimmick for people who are to lazy or dont want to replace the intake stuff and just bolt on a turbo kit. The kit will make more power without the stock eaton restricting the turbos
i think the advantage to tho running with a supercharger as well is you can run larger turbos than normal (in a twin turbo application) and the s/c would spool them up fatser. they actually said in the article that if the s/c was removed and a 4v intake manifold installed, that the car wouldve mad more power.
to correct my earlier post saing the article was in MM&FF, it is actually in the Spring 2009 issue of Hot Mustang Projects, which is published byt eh same people who do MM&FF i believe. here is a link
http://www.musclemustangfastfords.co...bra/index.html
