Will i need a clutch adjuster with spec II clutch?
I getting ready to order a spec II clutch and i wanted to know if i need to get an after market firewall adjuster with it. There was a comment on the spec stage I clutch that you needed the after market adjuster or else youll burn the clutch up because the factory adjuster wont let the clutch all the way out. Is this true?
even if its not recommended you should still get an adjuster and quadrant, the stock ones are horrible. If you want recommendation on what to go with id highly recommend the fiore Firewall adjuster paired with any quadrant. The firewall adjuster is pricey but designed better than the others.
http://www.lethalperformance.com/99-...nt-kit-p-10316
i just like the adjuster, it requires no tools to adjust it, you just turn it a quarter turn in either direction and it locks by itself. The quality is just better than others and it uses 4 bolts instead of 1 or 2. The clutch quadrant is the same as most.
everybody on this site will tell you the steeda cable is crap and dont buy it. ive had mine on for over a year now with no problems. i have the stock cable off my gt still it has 40xxx miles on it im trying to get rid of.
junior04
09-28-2015 10:53 AM
