Spun rod? Colapsed valve retainer? anything, anyone?
Old Mar 23, 2009 | 03:37 PM
1999GT's Avatar
1999GT
Default Spun rod? Colapsed valve retainer? anything, anyone?
Ok so my car has a ping/knock really hard for me to tell which it is-I have a sligth ting , ting at idle and after about 2500RPM + it becomes a faster louder ting/knock. I've done my research on both spun rod bearing "sounds" and valves! could not find which it may be.
The car has a slight different sound through the exhaust also with the problem, has more of a bubbly sound to it almost like a back fire but not really.
I am wondering what it may be and if you could tell me AND will any 4.6L 99-04 motor fit in my 1999GT "straight bolt up" and should i get a new tranny????
The car has not lost any power and seems to be driving fine besides that but i dont want to take the chance if it is a rod to shoot out my shiny hood
car has 117,*** miles
thanks to anyone
Q: What is it?
Q: Should i do a motor swap or rebuild?
Q: Will any motor fit of the following years 99-04 V8's??
Old Mar 23, 2009 | 03:41 PM
Fobra's Avatar
Fobra
Banned
there is no way to tell you on here. Its probably a bad lifter, thats a cheapo fix, just take off the valve cover and have a look/listen. If its a spun bearing youll know it quick and it wont last long
Old Mar 23, 2009 | 07:43 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
No "lifters" on our cars, Hydraulic Lash Adjusters (HLAs)...
Old Mar 23, 2009 | 10:38 PM
1999GT's Avatar
1999GT
ok sounds good-i will def check that out first-got to start some where right!
Old Mar 23, 2009 | 10:48 PM
black35th's Avatar
black35th
Can you tell if its coming from the front of the engine? I'm almost willing to bet on your timing chain tensioners/guides. If you can get a half way decent quality video it would help us tremendously.
Old Mar 24, 2009 | 05:37 AM
contentsunderpressur's Avatar
If your car has lost no power at all then it's probably a bearing gone bad. If it was a bad lash adjuster then it would be tapping, not knocking. Have you noticed any difference in your oil pressure after the car warms up?
Old Mar 24, 2009 | 11:18 AM
1999GT's Avatar
1999GT
It sounds more towards bottom back of motor-hard to tell, it will be kind of hard to get a video. And i understand that with only word it is very hard to diagnose a problem.
oil pressure seems fine and nothing out of the ordinary, i am going to have a buddy mechanic check it out tongiht i will def let you guys know what i find..
Wish me luck
Thanks
Old Mar 24, 2009 | 05:06 PM
lilc1511's Avatar
lilc1511
yea sounds like rod knock to me, good luck. its going to have to come apart one way or another.
Old Mar 27, 2009 | 02:04 AM
1999GT's Avatar
1999GT
Ok, WELL!! brought it to a guy i know-he basically put on his ear piece and took a listen-said it is def internal and could be the pin that holds the rod and piston together "wrist pin" or it is at the front the the crankshaft--soooooooooooooooooooooooo, i dunno. Also been reading up on loose headers/header crack almost making the same noise-so i suppose i should start simply with that first .
Idea's?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
