Low cost HP
lol, nobody answered his question at all.... he wants low cost parts, not a blower. heh.
your going to have to shop around for the lowest of low prices man, most places are pretty competitively priced but some places are lower in some areas (ie injectors or exhaust components) and higher in others....
all in all shop around everytime you buy a part. i haven't found just one site with all good deals.
Hi i recently got a crack in my intake manifold. I have a 2001 4.6 GT. While i was replacing the intake i was looking for something not factory and preferably something that would give me a little power. I thought while i was doing in i might as well do out and out some long pipe headers on it as well. I have never done any work like this on a vehicle newer than a 70 model and was wondering if some one could point me in the direction of some good low cost parts. When it comes to horse power i know the more money you have the faster you can go but im not looking to break any records here, maybe only build it up to 400 maybe 500 horse power when its all said and done. thanks in advanced
And that would be more likely a pro products. Yuk!!!
You are a noobie asking questions that I don't expect you to know the answers to, but if there's one piece of advice I can give you its, "Don't listen to other noobs that give cushy no help answers that sound like they should be coming out of Obamas mouth".
I'll restate and modify to my original statement. The factory design is a pretty good design and works well for most applications. You WILL NOT gain any substantial numbers from buying an aftermarket intake. Some loose power on the low end and only make it up for with only another 12-15 on the top end (Past stock cams power range anyway).
The Pro Products intake which is the only intake in the 500$ range is crap and with heat soak most people haven't gained any Hp at all. If you want to make ANY POWER AT ALL, get cams, heads, exhaust. You have to remember that because this is a 4.6, not one component is going to be a miracle bolt on. A full bolt on car is going to be in the range of 300-360rwhp and more leaning to the 300.
With a completely stock long block and exhaust manifolds, 10lbs of boost through a fmic and a V2 I made 436. I added cams and went to 488. Added heads and a pulley I went to 550.(lots of timing) Now i'm reaching for 580 with another $1k in parts....If you wanted easy hp you should have bought GM But then of course, you'd look like an over-weight catfish.
Welcome to MF.com
