H/C install help plz!
hey guys im in the process of reassembling the new heads and i had two questions for the experts here:
1. How exactly do i bleed the hydraulic lash adjusters and do i need to do it in order to fit them in the new heads? The reason im asking is cause they are a bit too tight to fit in the new heads.
2, Also whats the best way to install the cam gears on the new cams? Should i install heads, then cams and then gears in order to be able to torque the bolt on it properly or is there a better way?
Thanks for any help, once i figure out this dilemma im gonna start putting everything back together and slapping the engine back up there.
oh really well it seems as if the hole where they go in the new heads is a bit rough and dry. Should i just lube the hell out of it or what? Is is ok to hammer it in with a rubber hammer?
Is there a spot on the cam itself to hold it or do u just pry it or what? thanks a lot
09-10-2015 08:39 PM
