Cobra fuel tank vs MMR sumped tank???
Fuel sump http://cgi.ebay.com/ebaymotors/1979-...QQcmdZViewItem
-10 90* fitting x2
-10 straight fitting x2
-8 45* fitting x2
-8 90* fitting x2
-6 90* fitting x6
http://www.jegs.com/p/JEGS/752556/10002/-1
-10 orb to -10 an fitting x5
-8 orb to -8 an fitting x4
-8 orb to -6 an fitting x2
-6 0rb to -6 an fitting x3
http://www.jegs.com/p/Aeromotive/752051/10002/-1
-6 fuel line 20'
-8 fuel line 10'
-10 fuel line 15'
http://www.jegs.com/p/JEGS/752578/10002/-1
Y block http://cgi.ebay.com/ebaymotors/AEROM...2em118Q2el1247
hose clamps http://www.jegs.com/p/JEGS/763974/10002/-1
pump, filters, regulator, fuel rails of your choice but I suggest aeromotive.
http://cgi.ebay.com/ebaymotors/Aerom...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/New-A...QQcmdZViewItem
All of the lines and fittings can be subsituted by pushlock like I did to save money.
http://www.jegs.com/p/JEGS/773391/10002/-1
I cut the bungs off the sump and used weld on an fittings.
-10 90* fitting x2
-8 45* fitting x2
-8 90* fitting x2
-6 90* fitting x6
-6 fuel line 20'
-8 fuel line 10'
-10 fuel line 15'
-10 90* fitting x2
-8 45* fitting x2
-8 90* fitting x2
-6 90* fitting x6
-6 fuel line 20'
-8 fuel line 10'
-10 fuel line 15'
-10 90* fitting x2
-8 45* fitting x2
-8 90* fitting x2
-6 90* fitting x6
-6 fuel line 20'
-8 fuel line 10'
-10 fuel line 15'
My fuel tank $70
MMR fuel tank $549
Any questions
Using a sumped tank you will have to convert to a return style fuel system which is pricey but if you are gonna be making big power it's worth the money. Don't buy a kit cause it will cost alot more. If you want to go this route let me know and I will give you a part list and where to buy.
The cobra tank is good as is to about 500hp. After that you will have to upgrade pumps, efpd's, fuel lines and rails which will cost about the same as going return style.
MMR fuel tank $549
Any questions
that's a useless setup for anyone that road races.
Just to make sure this comment goes over well, that is a very clean and well thought out sumped tank.
stangin1996gt
09-21-2015 11:01 AM
panic
09-10-2015 05:56 PM
