Which one has more benefits? I was told the typhoon with the blower I'm getting would get me dome decent numbers but I was also told that the blower cams would make it easier on the supercharger I'm getting and allow me higher RPM's which means that my top speed goes up. Which one is worth it more to you guys and why? I have a 03 mustang GT with full exhaust.
Cams would be way better but the install and everything would make it a lot more money. The extra rpm would be way better, plus you can run a nice gear like a 4.10 (assuming its a centrifugal supercharger).
Cams would be way better but the install and everything would make it a lot more money. The extra rpm would be way better, plus you can run a nice gear like a 4.10 (assuming its a centrifugal supercharger.
It is a centrifugal but I'd like to keep my stock gears. Is extra RPM's the only benefit?
Yes blower cams will much better than typhoon intake its a no brainer. Just make sure you don't go to big of a cam especially if you are running stock gearing.
