Does the 4 bolt design allow for more adjustment? I need some and I was just going to get the cheaper steel UPR shark ones for $120, but they are only 3 bolt.
Perhaps a bit more, but mostly they don't bend and fall apart like the cheap pressed steel ones. It's up to you to decide whether your backside is worth saving $80.
"Unfortunately buying the cheapest there is very often means you will receive the cheapest there is..."
+1 for the MM ones, mine were installed in the competition orientation.
Right now at max adjustment both sides are -
Bad for tire wear but a great ride, and since I dont put a lot of miles on my car yearly I'm on my 4th year with these tires and the inside wear is just starting to make me consider new tires.
