trouble codes???
Old Apr 26, 2009 | 11:23 AM
MikeInCape's Avatar
MikeInCape
I do not believe Nate has LTs... Pretty much stock, right?
Old Apr 27, 2009 | 05:09 PM
nateCR's Avatar
nateCR
car is stock other then KN drop in and pypes x and slp LM1 exhaust in witch i have driven well over 3k with and not had a problem im pretty sure it has mil elminators on there as well. i have notice a little miss only at idle, should i replace the plugs and fuel fliter or look into the oxy sensors? but it gives both codes so both banks are doing it so you would assume fuel right? i did earce the codes and it took about 200 miles to come back on but it did today
Old Apr 27, 2009 | 05:13 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Check the trans harness for damaged wires. especially around the trans mount. If that checks out, check for vac leaks
Old Apr 27, 2009 | 11:40 PM
nateCR's Avatar
nateCR
well guys replaced the spark plugs and put a new fuel fliter in (old one was org motorcraft some nasty gas came out of it, and fixed a broken pcv hose (one from tb plenum to valve cover) and im hoping it does better, stopped missing, the plugs were starting to lose there shape.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
