Replacing rear blinker bulb?
How do you get to the bulbs for the rear blinker? I cant find a good write up on how to do it and it only says how to change the front blinkers in the owners manual.
mines burned out and its blinking 2x as fast
You mean blinker as in the taillight bulbs? because that is what does the blinking when we use the turn signals...unless you have cobra taillights?
If not then this guide from AM http://www.americanmuscle.com/99-04-...t-install.html
is a pretty good write-up you can use to replace the bulbs. I used it to replace my reverse lights for brigher ones. You will need a door panel remover and a 11mm deep socket.
Then again i'm not sure if replacing it will help since you said yours still works it is just blinking twice as fast
You may just be low on blinker fluid...it's sold out now, but Kaleco's pretty good about replenising their stock.
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
