Need Help! 96 GT, not running strong..
Old 04-14-2009, 03:30 AM
Deputy2B4Life
Deputy2B4Life's Avatar
Default Need Help! 96 GT, not running strong..
1st Day Post.. Just bought the car..
96 Mustang GT, Convert. 5 spd
160,000 miles
all stock except
Some kinda dirty lookin fender cold air kit+
Flowmaster Muffler
A old lady owned the car, and it appeared she didnt take good care of it. Although It came with brand new tires and new brakes and rotors
Hello, I searched the forum and couldnt come to any conclusions so I decided to post. When you start the car it sounds great. I noticed that the throttle response was kinda slow and it seems that it may have a slight miss at 4k. As soon as I drove the car, I wasnt impressed at all. It does ok until 3k then it feels like something is holding it back. and I put the car in 3rd gear, going slow to put a strain on the motor.. When I floored it, it was missing pretty bad.. Another friend told me he guarantee's its the filter and MAF.. Im thinking its that or maybe a fuel pump, but I donno.. Im gonna start my ideas this week, so any advice would be great. Thanks
Deputy2B4Life is offline
Old 04-14-2009, 12:36 PM
MikeInCape
MikeInCape's Avatar
Fuel Filter and Spark Plugs is where I would start.
MikeInCape is offline
Old 04-14-2009, 05:14 PM
Hangwire
Hangwire's Avatar
I changed my fuel filter @ 57,300 miles on my 2003 GT and what came out of it is best described as the black ****ing plague. It was utterly disgusting.
Sounds like youve got some kind of raggged out CAI and MAF. Got any friends to switch to their intake and MAF? Otherwise check plugs.
Hangwire is offline
Old 04-14-2009, 07:35 PM
Deputy2B4Life
thanks for the advice.. ill tear into her this weekend and let ya know.. thanks
Old 04-16-2009, 08:01 PM
Deputy2B4Life
Well, I put the car on a system scanner and here is the damage..
P1443 EVAP Purge Valve Fault
P0151 H02521 CKT Low Voltage
P0155 H02521 Heater CKT Fault
P1151 H02521 Snrs Indicates lean
P1152 H02521 Snsr Indicates rich
P0308 Cyl #8 Misfire
I didnt fully understand all of the codes, but I believe the majority are O2 Sensor related. The Misfire on cyl #8 is also a major issue.. Saturday, im going to take off the cold air tube, clean the MAF, Air Filter, and Throttle Body.. Ill replace the plugs as well and see if that fixes her.. I sure hope so, cause shes running like an old lawn mower
Old 04-16-2009, 08:26 PM
ct_white_stang
ct_white_stang's Avatar
You may need new 02 sensors as well. I would bet at 160K its time.
ct_white_stang is offline
Old 04-17-2009, 09:50 AM
wolverine8490
wolverine8490's Avatar
I would change the air filter, plugs and wires. Then clear the codes. That may fix the missfire code which may also clear the O2 codes. If the O2 code comes back, it looks like your O2 in Bank 2, Sensor 1 is bad.
wolverine8490 is offline
Old 04-17-2009, 10:35 AM
Deputy2B4Life
Well the wires look like their in good shape, so I think id be fine on those.. Im on a budget for the next few months.. I just bought the car.. lol Which 02 sensor is bank 2? and is Sensor 1 an O2 sensor? if so... which one? Thanks
Old 04-17-2009, 11:25 AM
2slow4me_need2makefaster
2slow4me_need2makefaster's Avatar
the o2 sensor at the back of your six cats there should be 2 of them there are four total 2 in front of the cats adn 2 behind them bank one is in front and bank two is behind.
2slow4me_need2makefaster is offline
Old 04-17-2009, 11:28 AM
and just cause the wires look good doesnt mean there working right and if they were removed improperly the could be damaged on the inside i had that on cylinder one wire it was broke on the inside changed and it took care of the problem of a nasty misefire at hire rr's
Quick Reply: Need Help! 96 GT, not running strong..
