How much boost increase?
Old May 16, 2009 | 09:41 AM
  #21
mustangman281's Avatar
mustangman281
Banned
Your not going to see 17lbs. At 3500 I'm making 7.4lbs and at 4700 I'm making 14.7lbs. On that run I only made 17.8 lbs 5700 cause I had a little belt slip problem back then.
Old May 24, 2009 | 08:56 AM
  #22
doughboy4.6's Avatar
doughboy4.6
Well took the car to 5500 rpm and seen 15 psi I think I will see 17psi I have a T trim do you?
Old May 24, 2009 | 12:38 PM
  #23
mustangman281
Banned
No I have a much better novi 2000.
Old May 24, 2009 | 03:13 PM
  #24
ddmsgtr1's Avatar
ddmsgtr1
Since we tripped onto the topic of what's a better blower, would you guys prefer a novi 2000 or a procharger f1a?
Old May 24, 2009 | 03:50 PM
  #25
Fobra's Avatar
Fobra
Banned
no... novi is a good blower but Id take an F1R, and actually a YSI over both
Old May 24, 2009 | 07:19 PM
  #26
ddmsgtr1's Avatar
ddmsgtr1
I like the idea of a monster blower, but isn't an F1R a bit more than you're really ever going to need on a 2V? I would think the f1a has plenty of potency for the flow of these engines.
Old May 24, 2009 | 07:55 PM
  #27
2000AZ5.0GT's Avatar
2000AZ5.0GT
did you datalog that or are you just assuming that's what you saw at that?
If not, I'd like to know how you could watch the road, your tach, and the boost gauge all at the same time with 500+rwhp
Oh, and your not going to see 17psi. Your going to loose PSI due to heat from overspinning the blower.
Old May 24, 2009 | 08:11 PM
  #28
mustangman281
Banned
Novi 2000, procharger D1-sc and vortech T trim are all in the same class with the novi out performing the other two.
F1a and YSI are in a class together but the novi 2000 is in very close competitor.
Bottom line is to get a d1 or T trim to make same power as a novi 2000 you have to run alot more boost.
Old May 24, 2009 | 09:15 PM
  #29
Sxynerd's Avatar
Sxynerd
He said his ol'lady was in the car with him watching the gauges with him but IDK.
Old May 24, 2009 | 10:18 PM
  #30
2000AZ5.0GT
well, then not only would there be a perceptual difference from not looking straight on at the gauge, but the chance that she was able to actually see clearly what was going on under that kind of acceleration.
