Will wide wheels hit wheel well?
I bought a pair of deep Bullit wheels 10.5 rear and 9 front. I was thinking of lowering the car also but not until later. The tire comes out to the edge of the outside of the wheel well as I've seen in a picture.
My question:
Will the wider tire hit the wheel well if I hit a bump hard enough or can it even travel that far. Also I have seen some spring kits such as Eibach Pro-Kit Lowering Springs. What if I used that kit would I need to change anything else especially if the wheel comes that far out.
My question:
RE: Will wide wheels hit wheel well?
I've rubbed 'em a few times but it was when backing out onto the road over
uneven pavement (315"s on 10.5 bullitts). I am sitting about 1-3/4 inches
lower than a GT. Roll your fenders. Iwill be rolling mine soon, big tires are
waaaaaay to expensive to ruin!!!
You shouldn't have a problem with this unless you slam the car, and even if you do, the springs are so stiff, it's unlikely. I had H&R Supersports on my 02 vert for a while and they never touched the fender. I thought they would. But they were too low anyway, so I raised the car with Steeda springs, 600lbs sq in and they never touch either; stance is nice.
mungodrums
09-29-2015 09:18 PM
09-08-2015 11:50 AM
