Trans. removal help?
Old Jun 18, 2009 | 09:20 PM
sn95maezes's Avatar
sn95maezes
Default Trans. removal help?
Whats going on guys? Im in the process of removing my facotry t45 out of my car because it seems to be stuck in 4th gear? Problem is, Im trying to get my factory H-pipe off, and the bolts for the drivers side between the exhaust manifold and H-pipe are EXTREMELY hard to get off and wont budge even after using an impact gun and torch. And then the passenger side I havent even figured out how Im going to get to those bolts next .... any helpful suggestions?
Old Jun 18, 2009 | 10:14 PM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Are you getting them red hot? If not, they may not be getting enough heat. The other thing to do is to spray them down with PB Blaster (that **** is Awesome) and let it sit for a couple hours to break up the rust, heat em up again, and then nail em with the impact. If that doesn't work then...
Old Jun 18, 2009 | 11:04 PM
03svtcobra12's Avatar
03svtcobra12
^^ PB blaster ftw. tried to turn the bolts on mine, wouldn't budge. sprayed it down, tried a week later and it popped right off.
Old Jun 19, 2009 | 01:44 AM
reznap's Avatar
reznap
I would have started cutting before I came in here and posted in forums... cut cut cut buy new. Spraying with penetrating oil after heating works well also, something I used to do on diesels a lot.
Old Jun 19, 2009 | 01:53 AM
JC316's Avatar
JC316
Pb blaster and the torch works for me. If it doesn't, well, I have a big assed breaker bar that I use. 32" long with a 1/2 drive on it, not much can stop it. Worst case, just use the torch to cut the bolts out and put an aftermarket pipe on.
Old Jun 19, 2009 | 08:08 AM
sn95maezes's Avatar
sn95maezes
thanks everyone, ive actually been using liquid wrench, but ill try it some more because i was looking to be able to bolt the H-pipe back up for inspections. i figured while everything was torn apart id pick up a nice x-pipe as a grad present to myself haha
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
guitarman376
Sep 30, 2015 05:54 PM
