problem?
Old Jun 18, 2009 | 09:52 PM
SilverGT03's Avatar
SilverGT03
Default problem?
what happens if you get a set of 4.10s installed and do not re-calibrate the speedo? The reason I ask is because originally I was going to get a tuner and 4.10s installed this thursday but now something has come up, leaving me with only enough for the gears and the install. Other than the speedo being off would it be bad for the car to go about 2 weeks with it off?
Old Jun 18, 2009 | 09:55 PM
mustangman281's Avatar
mustangman281
Banned
Nothing bad you will just rack up alot more miles on your car then you really are. Plus your speedo will be worthless and just have to go with the flow of traffic.
Old Jun 18, 2009 | 10:01 PM
SilverGT03's Avatar
SilverGT03
The rpms will still be fine though right?
Old Jun 18, 2009 | 10:08 PM
gunpig0313's Avatar
gunpig0313
Your rpms will be higher because you went to a lower gear ratio, but like mustangman said just go with the flow of traffic and you'll be fine.
Old Jun 18, 2009 | 10:21 PM
SilverGT03's Avatar
SilverGT03
ok cool. like I said it will only be for a week or two.
Thanks guys
Old Jun 18, 2009 | 10:23 PM
gunpig0313's Avatar
gunpig0313
Your rpms will stay high even after you get the tune.
Old Jun 18, 2009 | 10:28 PM
stang04chris's Avatar
stang04chris
If u do not program 4;10s in ur car u will be slower, it will screw up the way it runs, b4 I programed the gears in mine I was slower and my rpms where LOWER, how idk, but u will have 2 program with 410s
Old Jun 18, 2009 | 10:37 PM
SilverGT03's Avatar
SilverGT03
Care to elaborate?
If the speedo is off and the miles are a little off thats fine. I just don't want any mechanical problems
Old Jun 18, 2009 | 10:54 PM
mustangman281
Banned
There is nothing at all mechanical that installing gears will do to your car. You can run forever without tuning the car it will run no different at all.
Old Jun 20, 2009 | 08:57 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Unless you have an automatic transmission, the shift points and other speed related settings will be all screwed up...
