Need help! Motor missing poss after wash
ok here is the deal, 4days ago I bought a 02 gt Convertable 5-speed.
It was super dirty. I spent all day yesterday cleaning it. Last night I cleaned the motor. All I did was spray it with purple power, and spray it off with the water hose.
This morning I drove it about 50 miles and came back home. Run perfect.
I had to move it for a dumpster I ordered. Still ran perfect. I came back in and called around for new tires. Found some in about 30mins.
Went outside to drive the car to the tire shop and it had a stedy miss. I thought it may have somthing to do with the way it was seting. Drove it about 10 mins. Changed nothing. Took it back home and I heard a high piched screem. I poped the hood and could not tell where it was coming from.
I thought it may be a pully. So I took the belt off and spun the pullys. They all felt fine. So I started the car with the belt off and it ran perfect....
What could cause the motor to miss, but not with out the belt??? What should I do to pin point it?? FYI: the check light came on, but when I hook up the scaner it can't read the codes. It shows an error message
Yeah after I posted this I found them... Wow that's some crazy wires. Nothing like ls1 coils anyway.
I changed all the plugs and the wires. And it fixed it right up, crazy when I got to check the codes it showed missfire on 5cyl and bank 1-2 lean.
It's all fixed up good now, runs better then ever! But I have another question how do you keep trash and dirt out of the spark plug holes? When I went to change the plugs, it took longer to clean out the holes then it did to change the plugs! I was wondering if they made a cover for them or any tips on keeping dirt and water out of the holes.
Btw: I LOVE the set up on a mustang! So much eazyer then changing plugs on an lt1-ls1. Chevy needs to take a look at this set up for sure.
I thought it may have somthing to do with the way it was seting. Drove it about 10 mins. Took it back home and I heard a high piched screem. I poped the hood and could not tell where it was coming from.
it should but it doesn't... i have the same problem, the first time i changed plugs about a year ago there was all kind of sh*t down there that i had to clean out, otherwise i would have gotten dirt down in the cylinders.
