2 codes what do they mean?
It could be something else wrong but when you did your long tubes did you get a tune for them? They move the O2's downstream which can cause this code. I was getting this too originally when I installed mine. Here is all the other crap it could be though. Check the underlined ones first.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Electrical:
Damaged HO2S
Damaged PCM
Fuel System:
Induction System:
Vacuum Leaks
PCV system
EGR System:
Leaking gasket
Stuck EGR valve
Base Engine:
Oil overfill
Cam timing
In closed loop the PCM expects changes it makes in AFR to be read by the front sensors in after a specific delay that is set in the O2 Transport Delay table. This table specifies a delay time in seconds for load vs. rpm. Stock values range from 0.602s at 10% load and 1000 rpm, to 0.133s at 70% load and 3500 rpm.
When the sensors are relocated further away from the exhaust ports these values need to be increased.
lincolnshibuya
Dec 8, 2015 04:37 PM
