car shuts off
Old 07-20-2009, 10:50 PM
punisher03
punisher03's Avatar
Default car shuts off
my car will just randomly shut off some times when it comes down from rpms to idle??
punisher03 is offline
Old 07-21-2009, 06:24 AM
BOSTANG
BOSTANG's Avatar
Try cleaning the iac, If that dont work you will have to replace it . That what i had to do. At advance it cost like 50 dollars Then all was fine.
BOSTANG is offline
Old 07-21-2009, 08:44 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
I just cleaned my IAC, same issue, though getting the carbon out did fix me, I didn't have to buy a new one. It is like a 5 minute job, just need a screwdriver and a socket set with some throttle body/carb cleaner and you'll be done in no time.
ChalknCover is offline
Old 07-21-2009, 08:46 AM
4.698GT
4.698GT's Avatar
check for a vacuum leak while your in there
4.698GT is offline
Old 07-21-2009, 01:14 PM
devongarver
devongarver's Avatar
yup, IAC or vacuum leak for sure.
devongarver is offline
Old 07-24-2009, 04:06 PM
disposablehero27
disposablehero27's Avatar
have the same issue, hasn't shut off in a long time, but the rpms still do whatever they want when slowing down but hasn't shut off, you guys think replacing it all together is the key? New throttle positioning sensor, so know its not that.
disposablehero27 is offline
Old 07-24-2009, 04:07 PM
disposablehero27
i did clean the IAC real well, hasn't changed.
Old 07-25-2009, 03:25 AM
HEAVYMETALMATT
HEAVYMETALMATT's Avatar
Yeah, if it runs well at idle its not the aic. Since it only shuts off when rpm's are dropping to idle its a vacuum leak. Check that your intake is tightened down to spec(mainly the upper). That is about the only way I can think of that you can have a bad vacuum leak and idle fine. If it does happen to throw a lean code though, it is probably one of the lower intake bolts.
HEAVYMETALMATT is offline
Old 07-25-2009, 06:08 PM
GatorDude_97_GT
GatorDude_97_GT's Avatar
I had to replace mine 2 weeks ago... i tried cleaning it... worked for a day.. then i started acting funny again... so i just bought the new one... did the trick...
GatorDude_97_GT is offline
KEM Motorworks
08-14-2015 10:13 PM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
Quick Reply: car shuts off
