Old Oct 8, 2015, 04:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
check engine light
Old Jul 4, 2005 | 08:08 PM
btm's Avatar
btm
Default check engine light
If I have really fixed the problem that triggered my "check engine" light, will the light turn off on its own, or do I have to reset something?
Old Jul 4, 2005 | 08:10 PM
Fat Nick's Avatar
Fat Nick
I ♥ Acer
Default RE: check engine light
Unplug the battery for 20 mins.
Old Jul 5, 2005 | 06:17 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: btm
Depends on what turned it on. If it was an unplugged MAF sensor, that will turn off in minutes by itself. It was a fugged up 02 sensor, that's not shutting off for a while. Every code has a number of start cycles the engine has to go through before the ecu clears a code on its own.
Just unplug the (-) battery cable for a little while and clear it manually. If you really did fix the problem, the light will not come back on.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
