Sluggish performance?
Hi, please bear with me as I'm new - I've tried to search for the answer but I didn't find it!
About a year ago I bought my first Mustang, it's a 2000 GT, Manual. I've always loved Mustangs and I love it so far, the only thing is I'm worried I'm possibly not getting the performance out of it that I should be. My friend drove it and he said it seemed a little sluggish (he's driven Mustang's before). Then I read something on here and the guy said he can burn rubber in second and his car "throws his head back". Well, mine doesn't do that. I've seen all sorts of pics of guys with smoke pouring out the back of their Stang's, I might be able to do that if I floored the gas and dropped the clutch (never tried). If I had my car "idling" forward in first gear and floored the gas, should I burn out? If so, it doesn't. I'm just trying to get an idea of what I should expect since this is the only one I've ever owned/driven.
Just so you know, I've done the following to my car:
- Replaced spark plugs
- Put in a CAI (K&N)
- Cleaned the MAF wire
- Cleaned the IAC motor.
- Checked for obvious vacuum leaks
- Checked the resistance on the fuel injectors (and checked to make sure they were "clicking").
- Ran a fuel treatment through to clean the fuel injectors.
I'm out of ideas, in my Hanes manual it suggests to check the EGR, but I don't have the tool they say you need.
Any feedback is much appreciated!!
Phil
Phil
RE: Sluggish performance?
Really it depends on what mods the other guys car has.. If he has gears installed burnouts are simple. Find out what he has in his and then we can give you a more accurate response. The Mustangs stock is not that powerful, its the mods that make the car..
Edit: Also make sure the traction control is off if you try to burnout..
ORIGINAL: ultrashock2112
Phil
Phil
make sure you have the Traction control off, when you start the car it is on, you have to turn it off if thats not it. get it tuned because something is wrong, new plugs maybe, mine was running bad with a bad plug and coil.
Phil
Phil
ORIGINAL: ZW99GT
Youve never revved it up and dumped the clutch before? Are you like a senior citizen or something? If If u cant burn rubber with stock tires between 1st and 2nd, there is something wrong.
Phil
Phil
Just wondering because my car will chirp no problem but not actually burn through the gear at all. I've got Toyo's they are pretty grippy tires.
Excuse me, and very good point. I didnt clarify myself. I meant chirp, but with my old 245's i could break loose @ about 20-30mph if i reved it all the way and dumped the clutch. I did it while making a normal pass with my buddies bone stock 03 GT at the track 2 weeks ago. I wasnt used to the lack of traction and his bald tires.The 275's are much better.
when you say chirp, do you mean in first and second gear? it should be no problem to spin all of first with the T.C. off. if you can only chirp second when shifting from 1st at high rpm's then it sounds like you have a lack of power. i own a 04 gt with 15000 miles with not that many mods, and i can chirp second no problem at low speeds like 20-25 mph and low rpm's. and when i really get on it and i shift second hard it will spin 2nd and keep spinning till i back off the gas. this is a really hard question to answer just by talking about tire burning. the easist way to solve your problem is to race a nother mustang like yours with the same mods. also how many miles does your clutch have on it, the clutch can be slipping.
