two quick questions...help!
First of all, Ive read alot of different answers to this question and am confused. Is it ok to mix oil brands as long as they're the same weight? I.E. if my car currently has mobile 1 synthetic 5w 20 is it ok to add motorcraft 5w 20?
Second I've got an 02 GT andd my headlights are terrible..they're pointed pretty much straight at the ground and the adjustments are stripped any suggestions?
Mobil 1(and most others) say there oil is compatible with other oils whether its a dino, a blend or full synthetic.
http://www.mobil.com.sg/Singapore-En...Mobil1_FAQ.asp
https://www.mobiloil.com/USA-English...entionals.aspx
Dont mix reg and synthetic - other than that is up to you.
my questions is why mix though? why not just get the same stuff - but one other thing if your leaking fluid or something watch you don't mess with the level of friction modifier in it.
Either loosen the headlights and try to pry them up - or just get new headlights...
Honestly I would only trust what the Oil MFG say to do. If Mobil1 says it is OK to mix than it is OK to Mix. Other wise all your going to get on the Internet is a bunch of people opinions or **** that they are regurgitating
autoedit
Sep 27, 2015 06:37 PM
Sep 25, 2015 06:30 PM
