Stock Valve Train Support 480-500 rwhp?
I am getting ready to install my blower cams and Beehive springs but concerned that stock valves won't hold up to my HP goal and high rpms.
Does anyone know what stock valves and retainers can properly support or how has actually run stock heads with FI w/13 psi on a 9.5:1 compression.
I was looking at MMR valves (stock size) along with bronze retainers.
No problem running stock valves, retainers, keepers, etc to 500RWHP. Only thing really needed to be changed are the valve springs as long as you have enough piston to valve clearance on the intake. The stock valves in these motors are actually really strong and their only problem is the big lip on the end kills the piston to valve clearance.
We have a turbo car making 700ftlbs to the rear tires for the last 2 years with the stock retainers and keepers, and EV8 valves with Comp high load springs. Only time I recommend a retainer change is if you are going to hit 7000RPM on a regular basis as the aftermarket retainers are a bit wider and match the springs better.
Im like the guys above I woulden't Risk it you might be okay for the first couple thousand miles, but if you really start to run her you could run into some problems I would just get the retainers done! Just my 2 cents
If I do purchase new valves (stock) I will have to seat them by machining them. What are the chances of this creating more problems i.e. tolerance extra. I won't be doing them by friend who is a Ford Tech will be doing the work but I am just trying to under my risk.
I will be spinning her pretty high (i love acceleration and 4.10s
How are these retainers Comp Cams Valve Spring Steel Retainers (96-04 4.6L 2V)?
http://www.americanmuscle.com/mustan...tainer-2v.html
