Marh Pulley
Old Aug 10, 2009 | 12:17 PM
SoCalGT43's Avatar
SoCalGT43
Default Marh Pulley
i just bought a march pulley for my gt. and i was look @ the size differencr between the two and the march one seems smaller. is that normal and am i going to need to by a different belt?
Old Aug 10, 2009 | 05:52 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It and "underdrive" pulley, so yes it's smaller--if you just got the crank pulley then you will need a shorter belt.
Old Aug 10, 2009 | 10:55 PM
PistolPete79's Avatar
PistolPete79
you can get a overdrive waterpump pulley for it to fit i have a march pulley myself, i didnt really notice a difference with them on though.
Old Aug 11, 2009 | 09:40 AM
avlon06's Avatar
avlon06
arent march pullys piggy back? a no go if i recall correctly
Old Aug 11, 2009 | 12:40 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It depends on which set/pulley you buy--they make both.
They are however all made of aluminum which is easier and cheaper to machine because it is much softer than iron (Steeda's SFI crank pulley is iron). Aluminum is also a crappy material from which to make poly-V, or any belt drive, pulley--because it is much softer than iron.
Front main seal problems with aluminum crank pulleys are not uncommon--because aluminum is much softer than iron--and abrasive particles that get embedded in the seal will chew into the aluminum much faster than they would chew up iron.
March says they hard coat the sealing surface of the pulley hub which will make things better, but still not as good as iron.
The drive belt itself will also get abrasive particles embedded in it, which can chew up the drive surfaces of the "much softer than iron" aluminum pulleys.
Did I mention that aluminum is much softer than iron?
This may not be an issue for a showcar, race only, or weekend cruiser, however if yours is a DD like mine (25k+ miles a year) then it can be a yet another thing to go wrong down the road (no pun intended)...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
ctgreddy
Sep 20, 2015 08:35 PM
