boost and plug gap
There's a lot of things that causes this for me. I run Autolite 3924(one heat range colder). First of all, the gap is much shorter than say stock, so fuel cannot burn as efficiently. Second, with 15psi boost, that force blows right past the stock rings(blowby), leading to quicker fouled plugs. Also, the plugs are not meant for boost/racing. They are a street plug, that actually work well. Plus, they only cost $13 for 8. I wish I could explain it better, but basically: street plugs + 15psi + blowby + .025 = quicker spark blowout. Also, the car does run a bit rich(purposely) to save my head gaskets.
With the lower gap, the spark has to travel less which reduces spark blowout. Anytime more than 4 pounds of boost is seen in force induction engine the spark has tendency to be blown out, hence the reduced gap.
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
