Shaker scoops
Shaker scoops
i want to spend 1200 bucks on installing a shaker scoop but before that i need to know if those things do alot on a 2000 GT meang horsepower wise. For example the only mod on the mustang is cat back exhaust. please let me know before i spend a fortune
RE: Shaker scoops
It isn't going to add much, if any horsepower. At high speeds it would bring in more outside air which should slightly improve your performance, but it would not likely be enough to measure. You can get a lot more performance out of $1200 by buying a midpipe, rear gears, and a flash tuner.
RE: Shaker scoops
ORIGINAL: lexy
If you want it for looks, fine. But if you're looking for $1200 worth of power increase, get a CAI and plenum, gears, headers, H or X pipe, etc.
RE: Shaker scoops
that does make sence then forget the scoop because people told me that it would gain like 15 or more hp, thanks guys!!! speaking of 4.10 rear end how much miles a gallon am i looking at? and what would be the top end speed?
RE: Shaker scoops
hehe feel free to search the plethora of other threads where everyone argues about those very questions lord knows there are plenty!
RE: Shaker scoops
ram air idea in general only works at high speeds but honestly, there isn't any actual compression occuring at any drivable speeds so it's not really anything more than a neat cold air intake.
Without going into detail, the only way for a true ram air to work in theory would be a small opening in the front which leads to a larger chamber where, when air enters, it's hard to get back out because the force from the incoming air through the small opening keeps pushing back and forceing more in, to create decent enough pressure (like a couple psi) that the air inside the chamber is at higher density than atmospheric pressure would require tremendous speeds, especially considering that the engine on the other end is sucking it through at a pretty regular rate.
In counclusion, what you want is a cold air intake or, for real horsepower, a supercharger or turbocharger.
