lca's or grind the fenders?
i just ordered the extreme duty adj. lowers from maximum motorsports. they say it will raise the back up 2 inches to run a 28 inch tire. when they come in the mail ill put them on and let everyone know.
^ I think he is getting the weight-jacker style to push upward on the spring perch. I would think that going upward of stock would be advantageous to have adjustable length as well. I think the arm will become "short" as the car goes upward.
Jazzer
Jazzer
still confused..lol, are those necessary?
What in the world do control arms have to do with tires rubbing the fender? I was running the regular ole $100+ summit uppers and loweres with poly bushings going 1.4x 60fts and never rubbed anything(I take that back, I rubbed the parking brake line on the drags). OP, if you take a stock rear spring and cut one coil off it will sit like this on a 28in tire.
275/60 Futura
275/60 Nitto D/R
28x10.50 ET Drag
This is what it looked like with stock springs. It made a HUGE difference just cutting one coil.
275/60 Futura
275/60 Nitto D/R
28x10.50 ET Drag
275/60 Futura
275/60 Nitto D/R
28x10.50 ET Drag
275/60 Futura
275/60 Nitto D/R
28x10.50 ET Drag
thanks for the clarity man!!
im not sure why im rubbing. but im running a 28 inch tall tire because i cross the line at the end of the track at 6200rpms, with the shift light screaming at me. and yea thats crapital, i live 2 minutes from there.
