I have Question
Old 07-13-2005, 12:44 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
Default RE: I have Question
Does it have to be in the engine bay for best results or could you have thrown them in the trunk?
jdaniel is offline
Old 07-13-2005, 02:36 PM
mustangmike01
mustangmike01's Avatar
I do not no!
You got off my topic so I have question for you. This winter I'm putting in a 04 Cobra motor with the Whipple s/c 15psi. You said you're making all must 20psi, is that on pump gas? I thought 15psi was max? I read somewhere on the forum you have around 640rwdhp. Are you using 1 or 2 fuel pump(s)? Someone on the forum said I needed 2 for 600rwdhp.
Thanks
mustangmike01 is offline
Old 07-13-2005, 03:08 PM
mustangmike01
[quote]ORIGINAL: mustangmike01
This is bin going on for more them a year now. At night with all the lights on the gauges and head lights pulsate every like 30 seconds when I'm driving down the road. When I start her up, the airride compressor gose on and then 20 seconds later the 2 intercooler fans go on. When the fans go on the idea drops down to 700rpm and then goes back up to 1200rpm. I think I'm just using to much power.
Do you all think I need
A ground kit? Which brand and which one? I know they are big on the inports but has anybody down one?
A bigger alternator? Which brand and which one?
A different batter? Which brand and which one?
Thanks
[IMG]local://upfiles/15077/AACB04B33B2542838148E3C1A782AA81.jpg[/IMG]
[IMG]local://upfiles/15077/6F585AB3C1764AFCBE23CB5097E3B7E1.jpg[/IMG]
[/quote
Can anyone help me
Thanks
Old 07-13-2005, 03:24 PM
MarcusM
MarcusM's Avatar
haha damn, way off topic huh? I think you should get Optima battery, and for an alternator I don't have really have any "facts" on different ones... So i'm not going to say anything. The body kit, i have the steeda kit on my car, and its xenon. I like it because it's not fiberglass..
MarcusM is offline
Old 07-13-2005, 10:28 PM
mustangmike01
So the Optima battery, and the alternator you think will fix my problems with the electrical. Plus this weekend I'm putting in 2 12" subs and 1 2000 watt peek amp.
Old 07-13-2005, 10:59 PM
David_K
David_K's Avatar
get 2 optima batteries and you can mount the MSD boxes inside the car.
David_K is offline
Old 07-14-2005, 12:41 AM
04BlueGT
04BlueGT's Avatar
I've seen stronger alternators advertised in MM&FF. Move the MSDs and TWO Optimas to the trunk. Keeps things dry, cooler, and moves weight to the back. If you get the new Cobra motor, FRPP has cams and a different whipple available. Those and a dyno tune have pushed that stock motor to 601 RWHP.
Best of luck
04BlueGT is offline
Old 07-14-2005, 03:06 AM
MarcusM
MarcusM's Avatar
Bee You M Pee
MarcusM is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: I have Question
