Headers install?
Old Oct 9, 2009 | 09:32 AM
mvr's Avatar
mvr
BEST way to do LT's is to have an aftermarket K already on the vehicle or plan on installing one during the header install. you'll understand why i say this.
Old Oct 9, 2009 | 11:17 AM
PaintballFreak's Avatar
PaintballFreak
The motor can easily be supported by the oil pan just make sure you put a 2x8 between the flat part of the pan and your jack, and center the jack on the flat part of the pan. People do it all the time without a problem. It's not like we're working with a big block here.
You can also support the engine from above. For me it seemed like more of a pain to get it setup though. I would have had to take things off the motor because the intake bolts did not look sturdy enough to hold the weight of the motor, in my opinion. So I decided to go the oil pan route instead.
As far as parts go, I would recommend MAC headers (notice I have BBK LTs)
Old Oct 9, 2009 | 11:30 AM
Xemeth's Avatar
Xemeth
Originally Posted by SVTeeshirt
NOOO! is it just me or is that a biggg no no? I'd never do that lol.
The first guy said he did that too, i'd never even try holding weight on my oilpan.
I think pulling the motor 5 inches or so is easier.
It's perfectly safe to do this as long as there's a block of wood. Just don't use only the jack and you'll be fine.
When I drop the K member on jackstands and I'm not at work, I just use an engine hoist to hold the engine. I find it the easiest, and it doesn't get it the way.
Old Oct 10, 2009 | 01:49 PM
penroe71's Avatar
penroe71
I am looking to install LT headers, this is thinking a little out of the box, but I am looking to replace my heads.........can you install the header to the head then put the head on the block? Not sure if anyone has tried this but thought I would ask.
Old Oct 10, 2009 | 06:38 PM
cisurfer's Avatar
cisurfer
soo yeah i had to drop the tranny again today dueto a broken fork...the pass header came off again...im gettin pro at this...header install for me? 3hrs tops
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
