clutch chatter and engine vibration
i just got my 96 gt running strong again and i noticed there is some clutch chatter(i thought it was a tob) i noticed some engine vibration as well that was never there untill recently.
is my flywheel shot? or what can be causing the problem?
thanks
thanks
i havent done anything with the clutch.
i had a running issue and two 02 sensors needed to be replaced.
after getting it running straight again i noticed the engine vibration and its had a chatter for a little while.
Oh...I was thinking you replaced it while fixing your engine issues. Maybe you're flywheel is a little warped.
my clutch is chattering pretty bad now and lastnight i had the clutch pushed in and it kicked itself out of gear.
will anything get messed up if i keep driving it?
im not worried about the clutch or flywheel cause when i get it fixed ill be replacing both with aftermarket parts.
Do you have the stock clutch cable? on a 13 year old mustang, it could very well be stretched, possibly not fully disengaging the clutch. If you were to replace the clutch and flywheel, then definately replace the clutch cable. I used the ford racing adjustable, and it is simple and good.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
