Engine swapping
Old Nov 6, 2009 | 12:25 AM
alkureg's Avatar
alkureg
Default Engine swapping
Does anyone know if a 2005 f-150 4.6 v8 would fit in a 2003 mustang? Are the motor mounts in the same place and all that junk?
Old Nov 6, 2009 | 12:52 AM
Red Beast's Avatar
Red Beast
im not 100% on your situation, but i have heard of some guys who have tooken 2008 F-150 5.4's and put them in there S197 mustangs
Old Nov 6, 2009 | 02:28 AM
tx_zstang's Avatar
tx_zstang
The biggest issue with using a f150 engine has been the intake manifold.
Old Nov 6, 2009 | 07:14 AM
S281 E's Avatar
S281 E
Fitting is not the issue. I believe its the mating parts.
Old Nov 6, 2009 | 12:39 PM
MU71L4710N's Avatar
MU71L4710N
if its a mod motor it should fit. but like said, the problem with dropping in new motors usually comes to the intake manifold. any of the 5.4 motors (2v, 3v, or 4v) will drop into a mustang without any problems, except the intake manifold doesnt allow the hood to close. ALSO, the 5.4 uses an 8 bolt clutch and flywheel/flexplates while the 01.5 and up new edges use an 11 bolt. so in this instance you need to replace your clutch and flywheel. you may have that situation (not hard to fix, but can add cost if your doing this on a budget)
do you already have the f150 motor? do you have a v6 or v8 mustang? why not just find a 4.6l PI motor...you can find those for stupid cheap.
Old Nov 6, 2009 | 01:56 PM
Fobra's Avatar
Fobra
Banned
Probably because its a 3v.
Old Nov 7, 2009 | 06:33 PM
alkureg's Avatar
alkureg
i can get a new hood and clutch thats not a problem, is that the only issues with it?
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
