Getting hot
Old Jul 17, 2005 | 10:29 AM
MarcusM's Avatar
MarcusM
Default Getting hot
Ok I have a 1999 GT. Yesterday is the first time this has ever happened. It was just over half way on my temp gauge and the car started to "boil over".. I stopped let it cool and filled it up. It took quite a bit of water. By the way at the time I was driving about 40 mph and it was around 97 degrees or so... Last night, wasn't driving crazy, & it did the same thing, only this time the gauge was showing "H" .. it was really getting up there. I stopped let it cool down, and put a new thermostat in.. not 160, cause they had to order it..I thought maybe it was sticking.. So I drove it, did it again, almost right away. What could the problem be? I am getting so frusterated???!??!![:@]
Old Jul 17, 2005 | 10:55 AM
03GTType's Avatar
03GTType
Default RE: Getting hot
Does your radiator have a leak that you can see anywhere like when you look under your car?
Old Jul 17, 2005 | 11:14 AM
MarcusM's Avatar
MarcusM
ORIGINAL: 01GTType
No.. not at all.. the water will start boiling over at the top of the overflow tank..
Old Jul 17, 2005 | 11:17 AM
03GTType's Avatar
03GTType
This might be a pile of BS but I hope not. I had that problem in another car and if I remeber right I changed to radiator cap because it has to have a certain seal. This is what I was told to do.. [&:]
Edit, have you checked your water pump?
Old Jul 17, 2005 | 11:40 AM
MarcusM's Avatar
MarcusM
oohh.. good call on the water pump.. Never thought. But how would I check something like that.. ?
Old Jul 17, 2005 | 12:29 PM
IownaMustangNow's Avatar
IownaMustangNow
well if ur car like falls apart or sumthin marcus... lol ill trade u mine.. she runs fine...ahah i love the color of urs tho
Old Jul 17, 2005 | 12:40 PM
GreyStang's Avatar
GreyStang
ORIGINAL: MarcusM
Read my reply in general tech.. Double posting sux
Old Jul 17, 2005 | 12:54 PM
STANGTVERT's Avatar
STANGTVERT
I ♥ Acer
ORIGINAL: MarcusM
ORIGINAL: 01GTType
Are you using just plain water?....................just curious , I hope not...................
Old Jul 17, 2005 | 01:13 PM
MarcusM's Avatar
MarcusM
ORIGINAL: GreyStang
ORIGINAL: MarcusM
Ok yeah sorry about the double post. It is low now, so should I fill it up, and if I take the cap off, and I see water moving then the pump is still good, and if it is standing still, or not flowing then the pump is bad?
Old Jul 17, 2005 | 01:24 PM
MarcusM's Avatar
MarcusM
ORIGINAL: IownaMustangNow
Haha.. I'll keep that in mind. Thanks!
