Update to my engine noise problem
Old 11-18-2009, 05:36 PM
  #61
JC316
JC316's Avatar
Originally Posted by pinto18
Kinnda was guessing it was those. Any help on wheres a good place to buy a set ??
Pick your poison. Summit has the trick flow ones for $9 each. Local auto parts store around me has them for $8. I am salvaging the good ones from a 2V engine that I have.
JC316 is offline
Old 11-18-2009, 06:27 PM
  #62
jvog
jvog's Avatar
His noise sounds more similar to mine than yours did. Is there any reason why they would be good when I pull the motor but bad when I started up the new motor.
jvog is offline
Old 11-18-2009, 07:52 PM
  #63
JC316
JC316's Avatar
Yeah, mine was much more extreme since I had 13 bad so far.... Still checking and after I replace the 8 that are bad on the drivers side, I may still have a slight tick. I would imagine that he only has a couple of collapsed one.
Yes, during a rebuild, they loose their oil and the seals can crack and cause leaks. I have had this happen several times before with different cars.
JC316 is offline
Old 11-18-2009, 09:13 PM
  #64
jvog
jvog's Avatar
Hmm how hard was it for you to pop your valve covers off with the motor in the car? I imagine the back bolts might be a little difficult to get to
jvog is offline
Old 11-18-2009, 09:21 PM
  #65
JC316
JC316's Avatar
On the 4V, it's easy, there are no bolts in the back. On the 2V, it's pretty easy too, but the back bottom 8MM bolt is a tad tough to get at.
JC316 is offline
Old 11-20-2009, 08:15 AM
  #66
Mustang_NTriangle
Mustang_NTriangle's Avatar
Have you scoped your motor, drained oil or cut open your oil filter for any metal shavings? Next, I would there your motor down and resemble heads, spings, retainers, etc.
Mustang_NTriangle is offline
Old 11-22-2009, 09:26 PM
  #67
jvog
jvog's Avatar
I have drained the oil and checked for shavings and didn't find anything. I am going to pop the valve covers off last on this week probably. How hard is it to replace the lash adjusters?
jvog is offline
Old 11-23-2009, 02:44 AM
  #68
JC316
JC316's Avatar
Not hard. See here: http://www.allhardwood.net/images/46_4v_rockerarms.wmv
JC316 is offline
Old 11-23-2009, 08:15 AM
  #69
jvog
jvog's Avatar
Hmm. Thats for rocker arms, now I may be wrong but I thought the problem was that the little plunger things (that the rocker arms sit on) weren't filling up? Of course I have to take the arms off to get to them but how do they come out?
jvog is offline
Old 11-23-2009, 01:23 PM
  #70
JC316
JC316's Avatar
With a pair of needle nose pliers. They just pull right out.
JC316 is offline
Quick Reply: Update to my engine noise problem
