Old Oct 26, 2015, 02:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
What octane gas do I need to use for my 96-04 GT/Mach 1/Cobra
Old Jul 27, 2005 | 11:06 AM
Vert_Lover's Avatar
Vert_Lover
Default RE: TECH: What octane gas do I need to use for my 96-04 GT?
ORIGINAL: justingt
ORIGINAL: blownstanger
Whats a PI sawp and how can I do it to my 98 GT?...thanx guys
PI stands for polished/ported intake...basically it's sandblasting your head for [sm=bling.gif] and porting the intake and exhaust valves to make em bigger allowing more air to be exchanged through your engine...porting if you have the tools you can DIY but leave the sandblasting to the pros
You sure? PI seems to have a weird meaning, no one seems real positive... some have speculated at Performance Induction or something. On the 94 - 99 cars doing the PI swap increases the compression of the engine above that's stock on the 99+(which already have the PI intake) which is why you need the higher octance fuel.
Old Jul 27, 2005 | 06:21 PM
justingt's Avatar
justingt
i was just guessing...seemed to fit the acronym tho
Old Jul 28, 2005 | 05:59 AM
blownstanger's Avatar
blownstanger
It means power improvement.
Old Jul 28, 2005 | 07:06 PM
justingt's Avatar
justingt
OOOOOO yay! i learned something new teehee
Old Jul 28, 2005 | 07:55 PM
04GTgirl's Avatar
04GTgirl
Is there really a difference? I use 91 in mine. Is that not a good idea?
Old Jul 28, 2005 | 09:55 PM
Guest
Guest
Posts: n/a
ORIGINAL: justingt
PI, unofficially, means "Performance Improved" (or Power improvement, I've seen both on here). They're the heads that come on the 99-04 4.6L V8s in the GTs. They will net in a higher compression ratio when swapped onto 96-98 4.6L V8s. PnP means Ported and polished.
I'd suggest having a PnP be done by a professional as well as sandblasting. There are MANY easy ways to fugg up a PnP, and if you don't have a spare head to practice on, it makes it harder.
Old Jul 28, 2005 | 09:56 PM
Guest
Guest
Posts: n/a
ORIGINAL: 04GTgirl
You don't need to, but it won't hurt anything... except you wallet.
Old Jul 31, 2005 | 11:13 PM
Slick97gt's Avatar
Slick97gt
I have a question,
I am doing a PI swap on my car along with a set of comp cams x262ah cams and exhaust, along with a tune.
I plan on running a 100 shot of nitrous later on.
Will I need 93 octane gas, or will 91 work?
I can't seem to find any 93 in my area, Dodge City, KS.
Old Aug 1, 2005 | 07:16 PM
Dave2000GT's Avatar
Dave2000GT
Higher octane is slightly less explosive, so going higher than you need can actually lose a little bit of power / gas mileage
Old Aug 1, 2005 | 07:28 PM
Dave2000GT's Avatar
Dave2000GT
I think this information is wrong, octane rating is just a RATING.. they say 87 octane is 87% octane and 13% heptane ?!?! B.S.
ALL gas is almost 100% octane.. there are trace deposits of other hydrocarbons and impurities that will make the gas more combustible, and by removing them, or adding other deposits, the gasses octane rating is raised, meaning it won't detonate as easily. You can have octane ratings over 100, that alone should tell you all you need to know about this article.
Stop posting this crap or I'll have you banned!!
