New Guy with problems
Old Jul 22, 2005 | 03:50 PM
smaaz's Avatar
smaaz
Default New Guy with problems
Hi,
She won't idle with A/C on!?!?
I know, don't run it! But... (very Hot Here)
There are many mods to my 95GT triple black. Cold air intake, Vortec at 12psi, Ford Motorsport intake, Performner heads, mild cam, headers, off-road pipes, Flowmaster. Lowering springs, Mac upper and lower control arms, aluminum driveshaft, 373 gears, 98 cobra wheels; 245/35 front, 255/35 rear.
I think that is most of it... Why does it stall when I put the clutch in with A/C on. And why does the exhaust 'load up' with raw fuel when I down shift, man what explosions, suprised Homeland security hasn't pulled me over.
I'm guessing computer??
Any suggestions would be appreciated.
Steve
Old Jul 22, 2005 | 05:21 PM
justingt's Avatar
justingt
Default RE: New Guy with problems
you're guess is probably correct...do you have aftermarket fuel injectors? if you have a flasher module (sct, diablo etc.) cycle through allthe parameters and make sure the compy knows what's actually there
Old Jul 22, 2005 | 05:26 PM
smaaz's Avatar
smaaz
thanks,
yes on the aftermarket injectors, no on the chip.
Any computer recommendations??
Steve
Old Jul 22, 2005 | 05:31 PM
justingt's Avatar
justingt
o god man lol idk about the idling thing but having aftermarket injectors with no flasher is a defenite NO NO lol that would explain your gas in the exhaust problem....i suggest the SCT Xcalibrator 2. You'll also wanna flash the comp for your bigger tires else your speedometer is off. You had that supercharger installed professionally right?
Old Jul 22, 2005 | 05:51 PM
smaaz's Avatar
smaaz
yes the charger, heads, cam, intake, injectors, and I forgot the MSD 6A all prof installed.
Ill try the computer flash, a local speed shop suggest burning a custom chip and dyno tune.
Old Jul 22, 2005 | 05:55 PM
justingt's Avatar
justingt
sounds like a plan
djbigskrilla
Sep 20, 2022 01:04 AM
microgt
Aug 20, 2015 07:12 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
philster0306
Aug 10, 2015 11:33 AM
