I changed an oil in my 4.6 and instead of 5qt (according to capacities in a manual) I dropped 6
should I remove 1qt or is it not going to be harmful .
thanks
If the stick is reading ok then I wouldnt think twice about it. Just as long as its not over the max. Its the same way with my car. The manual says 5 but that only gets me to right at the minimum on the stick so I always add another quart to get close to the max or so.
I don't no what manuals you guys have but mine states 5.7 qt. It gives a perfect reading in the dipstick every time right in the middle. So ya, 6 should give you higher but still below tha max.
