subframe connectors?
i was wondering what are some good subframe connectors for my car? i wouldnt mind having them welded on or anything... its a ragtop... the stock ones suck and i want some better ones to help the body roll.
RE: subframe connectors?
Steeda has the best full length subframes. I have the regular ones on my car and I like them. www.steeda.com
And if you are increasing horsepower and doing hard launches then you need to strengthen your Torque boxes.
Battle Boxes kick *** and there is a set for the lower and upper boxes now. The lower battle boxes also help to keep your floor pan from deforming
Most torque boxes are welded and bolted. For late models, the opening in the lowers has to be widened. Some metal will be cut away, but the trade of is worth, I'm told. UPR makes them also.
http://www.uprproducts.com/shopping/...e%2BBox%2BKits
The best sub frame connectors out there are the Kenny Brown extreme matrix units. They provide the most in rigidity, but for almost all they are an overkill. Any standard sub frames from any company will do the job.
ORIGINAL: Birdieman4
KB extreme matrix is top notch. Only problem is the interior needs to be removed because all the welding that needs to be done underneath, I talked to a dealer
and he said it was roughly a 6 hour job. You can go with full KB full length sub connectors and always add the extreme matrix later on if you want extra support.
Best thing to do is at least get the full length in for now that is what I am going to do and maybe upgrade when I get some serious power.
which of these sets are the better of the three?
steeda
http://www.stangsuspension.com/store...?idproduct=382
MM
http://www.stangsuspension.com/store...?idproduct=179
stang suspensions
http://www.stangsuspension.com/store...?idproduct=544
steeda
MM
stang suspensions
